[SOLD] Small Block MP Mechanical Cam and Lifters Package - New
Rocket
U.S.A.
I have a new Mopar small block flat tappet cam and 16 new lifters. This was a package set sold by Mopar. This cam uses the mushroom style flat tappets.
A Eng. P3690589 Magna. Velocity 110 degree, 324 degree advertised duration .633" lift intake and exhaust using 1.5 ratio rockers. Valve lash is 0.024" intake and 0.028" exhaust. Cam still has dry lubricant coating from the factory.
Price is $175 shipped in the lower 48 states. I will ship internationally as well for the additional cost.
PM me with questions.
What are you looking to trade for, just curious? This would be a great cam for my bracket car. PM me with what item(s) your are wanting to trade for.
My personal preference is cash through PayPal. I will send you a.pm
This is a pretty agressive cam and needs to be matched with the rest of the combination. The lifters.also are.installed from the.bottom and not dropped in like regular solid.lifters. Lifter clearance on the bottom side should be checked with the cam installed to be sure the flat base has adequate clearance. A spot facing tool is used if clearancing is needed.
