moturbopar
Hi all, I have a set of new probe forged pistons 14cc dish. .030 for 360.
http://www.summitracing.com/parts/pbp-12351-030/overview/make/dodge
scat 6.123 rods, new in box, http://www.summitracing.com/parts/sca-26123
JE pro seal file fit rings, http://www.summitracing.com/parts/jep-s100s8-40305
would like to sell as a kit. Close $1000 worth of parts, asking $800
I have a set of NEW 2.02 1.62 EQ magnum heads that I'm wanting to sell. The heads are nicely setup. 2.02 + .100 intake valves. 1.623 + .100 exhaust valves. Has bronze liners, No porting . Comes assembled with single springs (125psi seat), chromoly retainers. hd keepers. Installed height of 1.73, retainer to seal clearance is .825" were setup to run up to .600" lift
Magnum intake pattern
Comes with crane rocker stud kit.
$1200
Also have custom ground howards Turbo hydraulic camshaft and lunati microtrol lifters, cam is designed for .904 lifters. Specs are dur 273 seat to seat, dur at .050 is 226, .3505 lobe lift, 114lc on a 108ic lift is .525 with 1.5 ratio rockers, .560 with 1.6 ratio rockers. $260 for cam and lifters.
Have 1/2 thick mild steel header flanges, for making your own headers, was going to use to make some turbo headers. $70
Have some chromolly 1.6 ratio roller tip rockers for magnum heads. Dont know the brand probably Chinese. $75
Edelbrock edl-7326 head gaskets, $50
Will consider making a package deals.
$1200
