[Found!] Small block pulley,alternator bracket, water pump fan spacer
themoparman73
Sanger, CA
Hello
I'm looking for the upper and lower pulleys on a non ac 318. Single Grove on top and two Grove on the bottom. Also looking for the alternator 3 piece bracket (spacer behind the alternator) and a one inch fan spacer.
Thanks Fabo
Will need to know if it's a'70 and later (aluminum water pump, passenger side inlet) or '69 and earlier (iron water pump, driver's side inlet) 318. The pulley depth is different between the two.
This type
