Rustyfish
Member
After rebuilding the front end on my '66 Barracuda I have finally been driving it quite a bit and finally got around to tuning etc. The original 273 bottom end is long gone, in its place is a 75 318 short block still with the original 273 heads. I went to time it and finally noticed that the timing tab has no marks on it. The damper has been marked previously with a piston stop by someone else previously. The car runs reasonably well for an old engine with blow by, but wanted to actually get a gun on it, but unsure how to proceed. It looks like it has been marked in a couple spots before. How to you read this type of tab?
You tuner gurus can chime in hopefully.
