I redrilled my Indy intake for LA style heads. If you need pictures let me know
I'd like to see that !
I had to do the same thing with that W5 SP I bought.... (measure 8 times, drill once)
Church in the morning but I will try to take some pictures and post in the afternoon
what's the purpose of the center punches around the ports?
gasket is bigger than the ports except at the bottom (intake upside down) slide the gasket down a smidge
what's the problem
Old school do not want the intake bigger than the head
but the 318 4bbls used the big intake on the small heads so what do I know
if you have to make a choice the top (roof) is more important than the bottom (floor)
Or you can port match your intake to your ported heads for the perfect match
Exactly right. In fact, the ports were raised .100 to prevent a dip in CSA.
Pittsburgracer, did you see how badly out of whack the OE W5 holes were drilled? They didn't even match the gaskets shipped with the manifold. LOL
Yes Indy makes a intake for magnum heads. I just got mine back from having it gasket ported. If you can buy a magnum m1 intake for 400-400 I say but it. When I bought my Indy intake last year any m1 magnum intake I could find was listed for $600 . I lucked out and found a guy needing money, I bought my Indy intake for 300 shipped. I think they are over 500 new now.I think i have seen them used on a Magnum head somewhere also so if they are available to fit magnums i bet the magnum mountingbosses can be cut down and holes corrected to work with a LA but thats sort of stretching it.
BTW are there no more M1 intakes? M1 singleplanes are not bad at all.
Still no word on availability...
Not according to their website.from what I understand summit are shipping them today .
Our first set is on the way as well....
