Selling this custom made turbo kit, it was made to fit in a early a body with a factory k frame and torsion bars, the early a body is the smallest engine compartment there is so theoretically should fit any Mopar car or truck.
This was made up of a modified headmen block hugger header for the passenger side and a pacesetter header for the drivers side (passenger header flipped to face forward) both headers are mild steel, everything else is stainless steel with v band clamps wrapped in DEI header wrap.
The crossover is 2 1/4 then merged to a single 3” into the 76mm VS Racing Billet 7875 .96AR T4 Turbo. With a turbo blanket. It has a 3” stainless down pipe that terminates at the passenger floor board and is notched to clear the torsion bar. It’s set up with a Precision 46mm wastegate and a Tial 50mm BOV. There is a Turbo Smart manual boost controller and an Extreme Velocity carb hat.
With everything pictured including an oil feed and return line. I’ve got over $6500 in parts, labor and materials. I’m looking to get approximately half the cost back out of it. Asking $3000 not interested in trades will ship if arranged by the buyer. I’m getting out of the boosted scene. Freight would be on a pallet shipped from zip code 97756 58” long 42” wide 24” tall 165lbs.
Also separately have an IRD Racing blow through carb with 1/2” carb spacer for all the boost reference points needed. $1100
Mopar performance valve covers with -10an bungs welded for a motion raceworks catch can. $225
Aeromotive fuel regulator A1000 part #13204 $150
Edelbrock small block super victor intake manifold part# 2815 SOLD!
AEM boost gauge & wideband A/F gauge $175
