[WANTED] Small block windage tray with bolts etc
That would be the pan on the right with the slotted holes, And the bolt on the left with the taller head. Or you can use 2 Hemi head bolt washers per bolt.
If you don’t mind DIY, all roller cam 360s had windage trays, not sure about the 318. Look for ‘89-92 360’s in the junk yard.
I've had 4 88-91 -360 la rollers 2 had trays and 2 did not.
