Small Bolt CenterLines
limegreen70
Pokorny Enterprise's
Milton PA
I bought a pair of SB center line wheels. They didn't come with center caps. My question is. Will standard bolt pattern caps work for these? I see them online. But they never say if they are for the 5x4 bolt pattern or not.
Are you refering to the Centerline brand replacement caps?
@limegreen70. The standard centerline caps WILL NOT fit a 5 on 4" centerline. .They have a smaller center hole, to have more meat to the inside of the small pattern.
The small ones are available, I think, only second hand, and run about three times as much as new normal cl caps.
I have three pair of 5 on 4" cl...... and no caps.
5 on 4 uses a 2 3/4" cap, standard cl auto drag cap is 3 1/8" hole.
The small cap MAY be the same as a 4 on 4 cl wheel, for Vega, pinto, vw, etc.
Lug Nut King ad on eBay says they have two new caps for 4 lug cl. $36 for a pair (pretty sure they only have one pair). C-20 cap. I think standard is C-70.
