Awesome guys on the rim help!
So I have a 64 Dart, has an 8 3/4 rear. I have it mounted on the stock pads, what size cn I fit under the car? In the old days an E-60-14 would just make it and I had the lip bent up a little for more clearnace.
I was thinking a 14x7 with a 215-60 in the rear and mabye a 14x6 with a 205-60 in front?
Or should I go with around the same size in 15"s?
Looking at a 215-60 or a 225-60 on the 15 is a little taller. And a 225 -60 is about 1/2" wider than a 215-60.
Also what about front disc brake clearnaces? What offset etc is needed?
Any input here would really help!
Specs on 14"
P195/70R14 BFG T/A Radial,Overall Diameter 24.8", Cross Section 7.9"
P205/70R14 BFG T/A Radial,Overall Diameter 25.4", Cross Section 8.2"
P215/60R14 BFG T/A Radial,Overall Diameter 24.2", Cross Section 8.7"
P225/60R14 BFG T/A Radial,Overall Diameter 24.7", Cross Section 9.0"
specs on 15"
P195/60R15 BFG T/A Radial,Overall Diameter 24.2", Cross Section 7.9"
P205/60R15 BFG T/A Radial,Overall Diameter 24.7", Cross Section 8.2
P215/60R15 BFG T/A Radial,Overall Diameter 25.2",Cross Section 8.7"
P225/60R15 BFG T/A Radial,Overall Diameter 25.6", Cross Section 9.0"
Kind of like this size for the height and seems rear width would be decent and should fit? It is a little taller yet the width get me a little more room.
P215/65R15 BFG T/A Radial,Overall Diameter 26.0", Cross Section 8.7"
On a 15x7 center offset rim?
And was thinging about this for the front end. I have front disc brakes too.
On a 14x6 center offset rim?
