The crank pulley is the same bolt pattern as a small block Chevy - but oddly enough, not a small block Mopar. Not sure if you'd have to use spacers to make it line up with the other pulleys.
Smallblock chevy water pump pulley with the holes drilled out to 3/8" it's a tight fit but it works, I may end up getting a smaller pulley when it is all said and done.
