SmallBlock Solid Roller Lifter COMP 828-16
Hemirunner
Down South
Rating - 0%
0   0   0
Comp 828-16 Solid Roller Lifters for Small Block Mopar, new in box. I'll never use these and I'm cleaning out the garage!!
$375 plus shipping. Will trade for 7.100 BBM H-beam rods or 3.750 or 4.150 stroke 4340 crank. PM me. Illinois.
These will work with unbushed bores as long as it's not an extreme lift cam lobe. Your typical .550-.650 lift deal works fine with these.
These are long body roller lifters so there is no requirement to sleeve the lifter bores or tube the block. Now having said that, sleeving the lifter bores or tubing the block is good insurance for any solid lifter or solid roller lifter motor if the lifter happen to pop out of the lifter bore.
..............thank u............kim.....
