bwhitejr
I don't have any experience with this so bear with me. I have just fired off my 360. I have set the timing and adjusted the carburetor. It has Edelbrock performer RPM heads and intake, a 625 AFB and a cam with 60 deg of overlap. I am idling it down 900 RPM. It isn't a smooth idle. It shakes ocassionally, like it suffers from poor fuel distribution problems at low RPM. It sounds good and strong when you get to 2k and smooths out. Is it normal for an engine like this shake at idle? Will the motor mounts handle this (stock rubber mounts)?
bwhitejr
bwhitejr
