Frnknsteen
I have the later disc brakes on my 69 Dart with LBP rallye wheels with no problem.
Is the backspacing on large bolt pattern rallye wheels the same as small bolt pattern rallye wheels? That was my concern. I don't know if small bolt pattern rallye wheels used with drum brakes are the same backspacing as large bolt pattern rallye wheels used with disc brakes.
All I know is I put a 3/4" spacer between the wheel and the hub and my tires were very close to the wheel well lip. I decided to hold off until I could just do it all at once, which will be after my Charger is complete and I have more cash available.
