Yeah I see that.Vacuum isn’t an all in one time deal. It’s constantly variable with load and throttle opening. So the can will add timing based on that. But it will be “all in” at a certain vacuum number.
Let's keep this simpleOkay, so first off I want to start this by saying I'm not asking to start an argument about which is better "ported" or "manifold". So let's not do that seen to many.
My question: when ported does the motor only use the amount of advance needed? As in when the motor is pulling say 1800 rpm does it only use the amount of advance needed at that point or does it try to use all advance regardless?
So if I turn my can all the way up as the advance comes in will it only pull the advance it needs or will I get the max 15*(on the can) the moment vacuum starts pulling?
My truck really likes the ported side, but I have kept it at its minimum of 8* to be safe and not get pinging. But that means at cruise I'm getting almost 30* should I attempt to push it till it pings and then back off a couple of * on the can?
I'm not sure why You want to change the spring, the allen screw should allow enough range of adjustment, unless it's some odd option app.My initial and total timing are set. What I'm asking is when ported does the carb act like a computer, basically only allowing as much timing needed at on time. Since the vacuum only comes in after acceleration, does this change affect how much timing is pulled? So if you open the can wide open but put a stiffer spring in, your initial timing should curve with the amount of vacuum being applied by the position of the throttle plates. Am I saying this correctly?
You're not talking screwing with the mechanical advance springs are You?!?! If so, no no no, leave that sh*t alone, You only need to adjust the screw in the can. The arm on the can controls the total the can add to the base & mechanical, if adjusting the diaphram spring tension to max is allowing light pinging or a slight surge, get a can with a lower advance arm.Got it, that's what I was asking.
So I can open my can all the way to the 15* it allows, as my rpms dont go high enough for the timing to be all in. My O/D and L/U make sure of that. My timing comes all in at 2200 rpm. But my cruising rpms are at 1600. I dont race this truck so I really never see 2200 rpms unless passing when I turn off the O/D and L/U. And it's not for that long. Almost all of my shifting happens between 1700 and 1800 rpms. Opening up my can all the way allows the motor to use what ever timing it would need without ever reaching a point where it would start to ping.I'm not sure why You want to change the spring, the allen screw should allow enough range of adjustment, unless it's some odd option app.
Ported is going to respond to the airflow/throttle position balance. If You're at 1/3 throttle on the level cruising @ 2800rpm, more air will be flowing & the vacuum will be higher(light load = more vac adv.), than 1/3 throttle climbing a slight grade at 1850rpm(heavy load = less vac adv.).
No I'm not talking about the mechanical advance springs, my timing is set at 22* initial and 36* all in. I'm talking about the can setting. The screw and spring inside. I was wondering if by changing that spring I could slow the rate at which the can comes in... but I dont think I can access it. I was also asking that if the distributor is ported then does the carburetor act as the computer and only pulls the amount of vacuum needed for the advance it needs at that time. Due to the fact that as the blades open more vacuum is produced, would it slowly raise the vacuum. I know that eventually the timing will be all in. But up until that point if the carburetor is acting as the computer it will bring in the vacuum according to the amount of throttle used and creating the "curve" or balance between firing and ignition. Man I can see the process in my head but I cant seem to say it correctly here. Maybe I'll make a video and try that way.
When you use the term "spring" I automatically think of the 2 springs affecting mech. advance.
Use the term screw or va. When talking vacuum. And yes the va curve can be adjusted with the screw. In reality you are adjusting the rate when adjusting screw.
You are over thinking this, these are simple systems doing simple tasks.No I'm not talking about the mechanical advance springs, my timing is set at 22* initial and 36* all in. I'm talking about the can setting. The screw and spring inside. I was wondering if by changing that spring I could slow the rate at which the can comes in... but I dont think I can access it. I was also asking that if the distributor is ported then does the carburetor act as the computer and only pulls the amount of vacuum needed for the advance it needs at that time. Due to the fact that as the blades open more vacuum is produced, would it slowly raise the vacuum. I know that eventually the timing will be all in. But up until that point if the carburetor is acting as the computer it will bring in the vacuum according to the amount of throttle used and creating the "curve" or balance between firing and ignition. Man I can see the process in my head but I cant seem to say it correctly here. Maybe I'll make a video and try that way.
Why can't You access the adjuster? It's a small allen wrench, is the hose nipple pointed right at/against something close?No I'm not talking about the mechanical advance springs, my timing is set at 22* initial and 36* all in. I'm talking about the can setting. The screw and spring inside. I was wondering if by changing that spring I could slow the rate at which the can comes in... but I dont think I can access it. I was also asking that if the distributor is ported then does the carburetor act as the computer and only pulls the amount of vacuum needed for the advance it needs at that time. Due to the fact that as the blades open more vacuum is produced, would it slowly raise the vacuum. I know that eventually the timing will be all in. But up until that point if the carburetor is acting as the computer it will bring in the vacuum according to the amount of throttle used and creating the "curve" or balance between firing and ignition. Man I can see the process in my head but I cant seem to say it correctly here. Maybe I'll make a video and try that way.
