[SOLD] built SB 727 & converter - $250
port-holio
Peoria, IL
Rating - 0%
0   0   0
(SOLD. Thanks Garner22! A+)
smallblock pattern 727 with ~3,000 miles since complete performance rebuild - removed from Abody in fine working condition for an overdrive swap. Drove to The Nats and a couple legs of Power Tour without issue.
All new bushings, bearings, seals, raybestos clutches/steels, and backup/safety switch. B&M Stage II shift kit, cast iron bands, fast ratio lever, 4pinion RV planetary, and deep Magnum pan. New filter & gasket. Kickdown was correctly set at all times. Comes with Abody dipstick & tube if you want.
Comes mated to 2,400 stall B&M converter, or if you prefer a NIB Summit 2,000 stall unit w/ new seal instead.
Pickup in Peoria, Illinois only. Cash, postal money order or in state check accepted.
Thanks for looking,
PH
Put me down as well, if all else falls through. I'm off work through next Thursday 23rd and could drive down any day except Monday with cash. Thanks.
