Oldiron440
Anybody else seen oiling problems with with hydraulic roller cams and lifters in an LA?
or just swap the valve springs. it's not like the heads even need to come off to do that either. it's a no brainer surely?Yes, I agree. Unless he's very careful. Maybe he can latch onto a friend or nearby member here who is more versed and can help him.
Yup. He certainly could. Although it's certainly less money if he goes that way, when a roller is right, you cannot beat it for power or reliability. It'd be a no brainer for me for the roller. lolor just swap the valve springs. it's not like the heads even need to come off to do that either. it's a no brainer surely?
i mean, how much is a set of springs compared to a roller can setup? he already has a cam and lifters that were fine up to now so reuse them and swap the springs in the new heads. and accept that he made a mistake but it won't happen again. why make that mistake even more expensive than it needs to be?
neil.
well, I USED to be a fan of aluminum rockers. They definitely have a lifespan.....or a cycle life. Here's a a Hughes after 5 summers. Granted, my spring pressures are 640ish, open.Mancini Racing Aluminum Roller, 1.6 Ratio I was planning on getting these rockers I heard there good to pair with trick flow heads
View attachment 1716325038View attachment 1716325039
Yea I was gonna do exactly what you did only difference is I’m going to end up doing a hyd flat tappet instead of a hyd rollerBTW.. if that's a 89 LA block it should have the bosses for hyd rollers.. i run a '85 roller LA using oem lifters and a hyd roller cam.. it works fine. plus lifters are like $100 for a set for oem and new ones are cheap also. You are basically doing exactly what i did.. i have regrets but it does work decently
I agree. My next build 422 is going to use the older non SS Comp Cams Rollers in 1.5 ratio I have here new in box. With Smith Brother's push rods after we measured for length.Not surprised the rocker broke. Look how thin the alum is, to the right side of the roller where the body has been machined for spring clearance. A great example of why it is best to use only steel or s/s rockers.....
good callYea I was gonna do exactly what you did only difference is I’m going to end up doing a hyd flat tappet instead of a hyd roller
