Solid rollers on a hydraulic roller cam?
Marcohotrod
Massachusetts
Sounds strange but why not try it? Made 10 more horse at 6500 on Engine Masters season 4 episode 7. lash at .002" . Maybe more reliable - who has run a hydraulic roller cam with solid rollers for how long?
I quest my question is then do you need to adjust the valve lash ever so offend? I like doing it, but just curious
My oldest son Brian has run his a few years 3 or 4. Last year he checked them twice. He is due to check them again. This is in his 4 door valiant, which is his only car.
He has a pretty mild cam though , [email protected] and 540 lift.
I want to add to what I said above, that Brian has 273 rockers. We did Yellow Rose's oiling mods to the rocker shafts, so the cups get plenty of oil. I think that is what keeps the lash from going .
i use through oiling on all'
I do not know how else to oil cup lifter-ball pushrod combination especially if the ball is set higher- which i what you want
