Some pictures of clutch pedal Assemblies
Oldmanmopar
Going left turning right
Danielsville Pa. 18038
I am getting pedal assemblies together to go with the rest of the clutch linkage I have. I thought I would post some pictures for reference for those who would like to identify pedals.
The pedals with the red springs are 70 -71 heavy duty with 5 3/4 pin spread taken from 340 cars. The clutch pedal also has needle bearings instead of plastic bushings.
The set with the blue spring is a standard set with 5 1/4 pin spread taken from 70 -71 slant six car. Plastic clutch pedal bushings.
The set with the spring removed for use with a diaphragm style Pressure plate is for 63-66 A-body That also has a 5 1/4 pin spread plastic bushing.
Seeing them side by side should help members identify Heavy Duty from standard sets.
Nice pics. I've always used Brewer's website to help ID various clutch/pedal/trans parts. Now I just need to figure out how to store a convenient link to this thread or PDF it somehow.
