Some small block dodge engine parts for sale. And some not mopar engine parts.
Black 69 Dart
Edmonton, Ab Canada
Rating - 0%
0   0   0
I am located in Gibbons Alberta, Canada (just north of Edmonton).
NEW! K&N High-Flow Air Filter, 14” diameter, 4” height $45
NEW! RCI Universal adjustable seat bracket (Part# 7451A) $30
NEW! Mopar mechanical flat tappet lifters for small block dodge (Part# P2843177), one set of 16 ($80 for set) and 13 singles ($5 each)
NEW! Oil slinger for small block dodge (Part# P5249636) $10.
Manley Valve Springs (Part# 221444-16). Good condition bbc. $250.
NEW! Retainers & 7 degree locks from a 572 big block Chevy.$45.
Crower titanium retainers (Part# 86067M) for dual valve spring. Good condition $175
NEW! Small Block Dodge Childs & Alberts main bearings (Part# M-27390-010), .010 under. $60.
Small Block Dodge Cloyes 9 Keyway adjustable double roller timing chain. Good condition $75.
MSD Ignition System, 6AL, blaster 2 coil, two step module. Good condition. $200.
8 ¾ Center Section, 489 casing with 4.56 Richmond gears and posi. Excellent condition, never been used. $800.
Oil Pan – 340 ($15 obo)
Oil Pan – 360 ($25 obo)
Auto Meter Fuel Pressure Gauge $60.
30 Polished
340 Connecting Rods Polished $30
360 Connecting Rods have 040 pistons on them. $40
340 Connecting Rods – $40. each set.
Have a set of Mickey Thompson and a set of Moroso, $55 each obo
2 Timing Chain Covers – Small Block Dodge $25 each
1” Carburetor Spacer $10.
Stock Converter – 360 Small Block Dodge, factory high stall 1600 – 1800 RPM, 727 transmission, needs helix coil $40
360 Rebuilt Distributor 1976 – Small Block $50.
Wilwood Disc Brake Kit for A Body Mopar for drum spindles. Includes new wheels studs (small or big bolt pattern). Used very little (12 1/4 mile passes) $600.
Headman Headers for A Body Mopar. 1-5/8" primary tube and 3" collector. Used very little. $100.
Mallory Comp Series 110 Electric Fuel Pump, 110 GPH and Earl's Performance -8AN Inline Fuel Filter $120.
http://edmonton.kijiji.ca/c-PostersOtherAds-W0QQUserIdZ68392323
Pics and adds here.
Have sold some stuff thought I would give an update.
NEW! Mopar mechanical flat tappet lifters for small block dodge (Part# P2843177), 13 singles ($5 each)
30 Polished
Trevor
Great guy to deal with , thanks Trevor. I really like my new brakes and headers.
Cheers.
How nice are the timing chain covers? Most covers are pitted on the gasket area making it hard to seal pump to cover.
Update on what I have left for parts, with pricing adjustments.
NEW! K&N High-Flow Air Filter, 14” diameter, 4” height $30
Manley Valve Springs (Part# 221444-16). Good condition . $150
NEW! Retainers & 7 degree locks .$45.
Crower titanium retainers (Part# 86067M) for dual valve spring. Good condition $150.
NEW! Small Block Dodge Childs & Alberts main bearings (Part# M-27390-010), .010 under. $50.
Small Block Dodge Cloyes 9 Keyway adjustable double roller timing chain. Good condition $65.
8 ¾ Center Section, 489 casing with 4.56 Richmond gears and posi. Excellent condition, never been used. $650 obo
Oil Pan – 360 ($20 obo)
340 Connecting Rods polished beams – $30 obo.
Stock Converter – 360 Small Block Dodge, factory high stall 1600 – 1800 RPM, 727 transmission, needs helix coil $40 obo
Trevor
Trevor
Still have a few things left? Want this stuff gone no reasonable offers refused
Trevor
