moparlee
64 Valiant
Yeah those march pulleys are underdrive right? means your water pump turns slower too huh?
Yes, I'm trying to figure out what to do about my heating problem. I'm about to put the original pulleys back on.
what are you using for a thermostat ????get your self a mr gasket or other name brand,,jegs/summit/local speeed shop get a high flow 160 degree and try that,,, how many rows in that rad ???
Lee, the car looks really good. I'm calling out let's get'r on. Will you going to Tulsa with it? Would make and excellent event to debute at. Jim
Lee, that car is totally awesome! Nice job! Dumb question: The solenoid in the trunk is a battery cut-off, right? What other functions do you use it for? Have you wired your alternator directly to the plus side of it? I need my battery cut-off on mine to shut the engine off, so I am just goung to run a #8 wire from the alt to the battery plus, but if you have done something better I would like to steal you idea! LOL! Thanks again for the great pixs and keep up the good work. She should run awesome!
Jeff
A 160* thermostat WILL NOT fix a cooling problem...it might make it worse. A thermostat will only effect coolant temps if it sticks closed other that that it has no effect on max temp. That is determined by the radiator, fan, water pump and other engine factors.
Sounds like you are going through what I did a while ago. Ditch the FlowKooler pump...they suck. I bought into the hype to and it is BS. Get yourself a stock replacment pump from NAPA or someother parts store. Get an 8-blade unit for a HD cooling system from say a 3/4 truck with a 360. Then put a Mopar Viscious fan on there and say goodbye to your cooling problems. Mine rides the 180* thermostat all day long now even in 90+ temps.
Are you running the March pulleys?
Yep....They were the next thing to go if the other changes didn't fix the problem. Try the Viscious fan first.....then swap the WP then the pulleys. That Viscious fan pulls a S-load of air. I also run an aluminum 1" 2 row crossflow radiator.
Give you email and I'll send you a tif diagram from what I got from MAD. It's for mopar only.
Can you tell me how big that fan is? As from the top of the radiator to the bottom of the radiator. I would hate to buy it and it not fit in the shroud.
