Mopar-Man
Big Block Better Burnout
GREAT bike. Rode a buddies when they first came out and marveled at the single sided swingarm. Always wanted one. I like the sound of the gear driven cams.
my first ride was a 83 MTX50
fun little bike
i still have a few kawasaki KDXs (one each, a 200 and a 220, the 200 is plated and sees road duty when the duster isnt up for it)
but i always enjoyed this one...it was my sisters bike
That definitely affects handling and will be dangerous when the tire gets on its edge. Motorcycle tires are soft for a reason.
Your opinion is irrelevant, as my experience, and thousands others, have proved you wrong. If anything, the flatter profile, actually leaves MORE tread on the road. Also, nA MC tire always has a small patch on the road, regardless of the bikes angle. The car tire actually has most of the tire in contact with the ground, and in sharp turns it has about the same amount of tread on the ground as a MC tire. I have ~70k miles on a CT, and I won't lie, it does handle a little differently, but after ~100 miles, you don't even notice, except the improved braking and more grip on takeoff. That you definitely notice.
Edit: And you can lean into the curves just as well as with a MC tire. I put new cobra floorboards on last spring and I have already ground about 1/2 of the lip off of them in the twisties. Not bad for an almost 800lb monster bike.
So my opinion is "irrelevant", yet you agree with me that the bike handles differently. I bet you could teach the motorcycle tire manufacturers a thing or two. Rock on, dude!
View attachment 1715039971 View attachment 1715039972 Here is what has gotten between me and my Lancer. First picture is 1976, second is the restoration from last year! Only 40 years apart. 1973 Norton 850 Commando.
