1BadDodge71
FABO Rice Hater
ok,i posted my stalling problem in the fuel thread,but now I may have a ignition problem.The engine starts fine cold,then after awhile it stalls and dies.Today,it did that and I plugged in a spark tester(the kind that looks like a plug and shows a spark jump across)and I was not getting a spark.I also tried using a test lamp ,the ground lead on the (-) side of the coil,and the end of the test light on a ground .I cranked it and the test light did not flicker on and off.So I waited a few hours and a little while ago,I went out and tried it again and now I have spark.Symptom of a failing module?:shock:The coil is ok.I even tried an extra good coil and still nothing.
