tekslk
These valve springs are double springs, on a street driven car that see 6200 once in a great while. I doubt it is valve float. Heads arent off we will change seals and springs with air through the spark plug hole.
My machinest wants to put something in there I forgot what he called it to keep the springs from moving around. After measuring inside spring diamater, than the valve seal with there shouldnt be a problem if the springs are jumping around. I wonder why it wasnt done like this the first time? Also untll this web site makes it easier for a old man like me to post pictures it aint gonna happen.
One concern I thought of is, what diameter valve springs are installed now, OD? If the're too much smaller then the pocket, they can "dance" around on you enough to possibly cause interference on the inside.
If that's a possibility, a seat cup/locater may be available to keep the spring centered?
Well if you think that is interesting, there have been a few engines with 'spring rotators'. Opel 1.5L/1.9L in the 70's had spring rotators, which were kinda like spring cups but were a 2 piece item with smooth surfaces between so that the exhaust valve springs did not snag on the head surface and fail to rotate. (Which would have caused premature guuide wear...)I never knew about spring cups myself, glad to have learned about them here. From what I read, they were designed for aluminum heads to protect the spring seat from being galled by the leading edge of the spring coil and to locate the spring concentric with the guide.
Looks like there's two types available, one style has an outer locating cup and the other style are flat on the outside edge with a step around the guide. Not sure why you'd use over the other.
