shanker
Reproduction harness (about 15 years old).
My repair. It took a couple tries using this terminal (standard width crimps). Note the feed wire is SAE 16 ga and the wire continuing to the voltage regulator is 18 ga.
Factory '67 Ignition Start & Coil feed junction. I dont have a pic of the original for the other one. Now I'm curious if it also the terminal was made for a wire pair even though it has the smaller gage wires.
And here's the same terminal junction on the M&H repro harness
Thanks....I guess I can either try the different dies (for the sake of not waiting around I ended up making the connection work with a regular terminal) or I can buy the real tool (which I more than likely will).
Mattax, you're commitment and knowledge contribution to the topic of wiring harness restoration and repair is truly commendable.
