[SOLD] Southwest Speed 1-7/8 Big Block Headers -new- $300
Jeremiah (jd)
Rogue River, OR
I have a new, never ran set of 1-7/8 Southwest Speed (ebay) big block headers. They have been sand blasted and sprayed in flat black VHT Flame Proof paint. No hardware is included.
$300 OBO buyer pays shipping.
HEADER,BB MOPAR,1 7/8,67-74,LONG T,3,BLK​
  • BRAND NEW PAIR OF SOUTHWEST SPEED PAINTED FLAT BLACK LONG TUBE HEADERS FOR 1967-1974 BIG BLOCK MOPAR 383-440CI ENGINES
    FEATURES:
    • 1-7/8" PRIMARIES TO 3" COLLECTORS
    • INCLUDES A PAIR OF 3" TO 2-1/2" REDUCERS
    • SAP PORT SHAPE
    • MORE PERFORMANCE
    • BETTER FUEL MILEAGE
    • INCLUDES GASKETS AND MOUNTING HARDWARE
    • PAINTED FLAT BLACK TO RESIST EARLY CORROSION
  • APPLICATIONS:
    • CHRYSLER:
      • 1967-1974 TOWN & COUNTRY
    • DODGE:
      • 1970-1974 CHALLENGER
      • 1967-1974 CHARGER
      • 1967-1974 CORONET
      • 1967-1969 DART
    • PLYMOUTH:
      • 1967-1974 BARRACUDA
      • 1967-1970 BELVEDERE
      • 1970-1972 CUDA
      • 1967-1974 FURY
      • 1967-1971 GTX
      • 1968-1974 ROAD RUNNER
      • 1967-1974 SATELLITE
  • HEADER SPECS:
    • MATERIAL TYPE: STEEL
    • HEADER TUBE TYPE: FULL LENGTH
    • FLANGE THICKNESS: 3/8"
    • FINISH: PAINTED FLAT BLACK
    • HARDWARE INCLUDED: YES
    • GASKETS INCLUDED: YES
    • TUBE OUTSIDE DIAMETER: 1 7/8"
    • COLLECTOR DIAMETER: 3"
    • REDUCERS: 3" TO 2 1/2"
  • NOTES:
    • WILL NOT FIT MODELS EQUIPPED WITH AIR INJECTION CYLINDER HEADS
  • PAINT WARNING:
    THESE HEADERS ARE PAINTED WITH A HIGH HEAT DULL BLACK PAINT. IT WILL GENERALLY DULL EVEN MORE WHEN THE ENGINE IS STARTED. THE HEADER PAINT WILL SMOKE AND LET OFF AN ODOR THE FIRST FEW TIMES THE ENGINE IS UP TO TEMPERATURE AND THE BLACK FINISH WILL BECOME DULLER TURNING CLOSER TO GRAY IN COLOR. IF EXHAUST TEMPERATURES ARE EXTREME AT START THE PAINT WILL BLISTER AND PEEL. THERE IS NO WARRANTY ON HEADER PAINT.
    HEADER RETURN POLICY:
    PLEASE REFER TO THE HEADER MEASUREMENT CHART BELOW TO MAKE SURE THE HEADER WILL FIT YOUR VEHICLE AND APPLICATION BEFORE ORDERING. IN THE EVENT YOU ORDER A HEADER THAT WILL NOT FIT YOUR VEHICLE AND APPLICATION, YOU MAY RETURN THEM FOR A REFUND, PROVIDING YOU DO NOT DAMAGE THE HEADER. WHEN YOU RECEIVE THE HEADER THE FINISH WILL BE PROTECTED AND MUST REMAIN UNSCRATCHED FOR A REFUND. IF YOU BEND OR DIMPLE ANY OF THE TUBES OR SCRATCH THE FINISH, WE WILL NOT BE ABLE TO SELL THE HEADER AND WILL NOT BE ABLE TO PROCESS A REFUND. USE CARE WHEN TRIAL FITTING HEADERS. REPACK THEM WELL TO PREVENT DAMAGE RETURNING THEM TO US. WE WONT PROCESS REFUNDS FOR SCRATCHED, DIMPLED, DENTED, OR BENT HEADERS.
    YOU CAN VIEW AND DOWNLOAD THE INSTRUCTION BOOKLET FOR THESE HEADERS HERE.
Part #440-2666
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100101102103104105106107108109110111112113114115116117118119120121122123124125126127128129130131132133134135136137138139140141142143144145146147148149150151152153154155156157158159160161162163164165166167168169170171172173174175176177178179180181182183184185186187188189190191192193194195196197198199200201202203204205206207208209210211212213214215216217218219220221222223224225226227228229230231232233234235236237238239240241242243244245246247248249250251252253254255256257258259260261262263264265266267268269270271272273274275276277278279280281282283284285286287288289290291292293294295296297298299300301302303304305306307308309310311312313314315316317318319320321322323324325326327328329330331332333334335336337338339340341342343344345346347348349350351352353354355356357358359360361362363364365366367368369370371372373374375376377378379380381382383384385386387388389390391392393394395396397398399400401402403404405406407408409410411412413414415416417418419420421422423424425426427428429430431432433434435436437438439440441442443444445446447448449450451452453454455456457458459460461462463464465466467468469470471472473474475476477478479480481482483484485486487488489490491492493494495496497498499500501502503504505506507508509510511512513514515516517518519520521522523524525526527528529530531532533534535536537538539540541542543544545546547548549550551552553554555556557558559560561562563564565566567568569570571572573574575576577578579580581582583584585586587588589590591592593594595596597598599600601602603604605606607608609610611612613614615616617618619620621622623624625626627628629630631632633634635636637638639640641642643644645646647648649650651652653654655656657658659660661662663664665666667668669670671672673674675676677678679680681682683684685686687688689690691692693694695696697698699700701702703704705706707708709710711712713714715716717718719720721722723724725726727728729730731732733734735736737738739740741742743744745746747748749750751752753754755756757758759760761762763764765766767768769770771772773774775776777778779780781782783784785786787788789790791792793794795796797798799800801802803804805806807808809810811812813814815816817818819820821822823824825826827828829830831832833834835836837838839840841842843844845846847848849850851852853854855856857858859860861862863864865866867868869870871872873874875876877878879880881882883884885886887888889890891892893894895896897898899900901902903904905906907908909910911912913914915916917918919920921922923924925926927928929930931932933934935936937938939940941942943944945946947948949950951952953954955956957958959960961962963964965966967968969970971972973974975976977978979980981982983984985986987988989990991992993994995996997998999
Add To Cart​
This item requires an additional shipping fee
of $20.00 over standard shipping.
Click Picture
For Larger View​
What kind of car do you intend to use them on? Engine, trans, steering type etc. As you can imagine my experience only goes so far with all of the possible part combinations.
If you want headers that fit really good there is no substitute for TTI.
70 Challenger. 383 4 speed. Just wasn't sure if had actually fit them in a car. I understand that mods might have to happen.
I would think you should have no issues in a 70 E body. I have mocked them up and the z bar is clear of the tubes etc. Sounds like a very cool car! If you want any pics of the headers bolted to an engine I have a big block in the shop on a stand.
