Small Block
Bought new ring and pinion and install kit along with new axles w/ green bearings. My question is, in the package there was a solid spacer that came with the axles from yukon. It fits well between the two new axles after being installed in the housing. All seems well. Stock width. Is this correct? Is this spacer needed?
