-I'm having a little trouble understanding "As you open the throttles the spike moves out of the manifold and into the filter house, creating more popping and havoc." If you could provide a bit more detail that would help me out.
No problem;I'll do what I can.
--The pressure spike in question is when the pressure momentarily
drops on the guage as compression pressure blows past an open intake valve,and enters into the intake,and the pressure there-in rises . The gauge reads it as less vacuum, so the vacuum drops.
--This is the same reason big cams idle at low manifold vacuum; the pistons are ALL continuously blowing some pressure back into the intake.
--This is all fine and dandy as long as the pressure stays in the intake, and as long as the intakes all eventually close before the fire gets lit. If an intake is still open when the spark ignites the charge, then, the fire travels into the intake and lights anything in there, and that is the pop you hear.
--Now, if you are stepping on the gas, and the butterflies are open, then this hot expanding gas can leave the intake and travel backwards through the carb and into the air filter house. Since the carb venturies don't care which way the air is traveling through them, they can dump some gas into that wrong-way airflow. This same airflow is at a higher pressure than atmosphere, so momentarily the low-speed circuit quits.As you open the throttle a little further, following pistons begin to suck(sic) this hot expanding gas out of the plenum and a point is reached where equilibrium may be restored. However this hot burned gas is now inert as it enters a next-firing cylinder, diluting it's charge, possibly pre-igniting it, so now you have a second popping cylinder.This is havoc. As the rpm rises, all this havoc may diminish because there is no longer enough time for that initial pulse to get far enough up the runner. In fact if you burn an intake at 3000rpm, traveling down the highway, you might not even notice it until you slow down for a stopsign.
--Now let's talk about why the intake might not be closing. There are at least three reasons that I can think of; #1) it's burned, and #2) it is lashed too tight, and #3) it has a mechanical problem, such as it's bent, or there is a guide problem or there is a hydraulic lifter problem or a spring problem.
--The LD test will determine if there is a valve problem, and which one is the trouble maker. Then you have to figure out the why of it.
