Spark plug article
Kendog 170
Let the boy go !
Reading Ma.
I was reading a spark plug article online. I have always use champion plug 12 heat range so never tried a hotter or colder plug. I found this interesting as different plug manufactures have different heat indexing.
Quote from article.
It is also important to note that Champion plugs use a larger number for a hotter plug while NGK plugs reference heat in the opposite direction, with hotter plugs using a lower number. So, it's important to know your spark plug manufacturer's reference numbers regarding heat range.
Just throwing this out there.
Here's a NGK cross reference chart I found.
The biggest mistake enthusiasts make is using a colder plug...when they should be going one step hotter.
