Spark plug drool tubes gaskets replacement
French demon
South of France
Hi all,
As my 198ci has drool tubes, I've read that the spark plug crush washer has to be removed before installation.
But about the drool tube gaskets?
Do I have to replace them each time that I replace the spark plugs?
Thanks
Usually, you don't have too.
But if it's drooling before or after you do............
Got mine from NAPA. I've got nothing to compare them to though, but they seal.
Tighten them and they will pull down into the head and seal. Removing the spark plug later wont disturb the tube.
Thanks Rob! I dug thru his listings a bit further and found a set without the plugs, appreciate ya man!
Cool. I don't know why they didn't pop up when I did a search. Glad you found up.
For the rest of you coming to this thread looking for more details, the part number from the '74 parts manual is Chrysler 1947 708. I'll follow up with more matches.
Hi all,
Correct. Also review tune-up parts and technique suggestions in this post.
"Spark plug tube seals".
Not every single time, no, but when they've grown hard and/or begun to crack, then yes. See here.
