Snake
Mopar Nut
Have look on line and cant find the part #for Taylor made or accell, 8mm what i need 6 straight and 2 90 degrees can someone help in my search please.working on a little 318.
What's the application other than a 318?Have look on line and cant find the part #for Taylor made or accell, 8mm what i need 6 straight and 2 90 degrees can someone help in my search please.working on a little 318.
If the parts stores can't find them, then its time for plan 'B'!ok i have done my own wires myself before, i like it that way for sure but trying to find a set with 6 straight and 2 90degree is like pulling teeth,i have bought them that way, but its been 7 years,but all the parts store cant find them.
When making your own wire sets, a little dielectric grease around the wire helps it slide through the boot as you're assembling. I use a small set of needle nose to pull it through if it gets stuck in a 90* boot.
