challengergary
Okay, maybe I have too much time on my hands today but I was wondering, do the claims that different spark plug manufacturers make really hold up? The way I see it, if you fill a room with atomized flammable gas and then introduce an ignition source to the equation, aren't the explosive results the same? Would it matter if you used a blowtorch to ignite the room or a match? Not really, you'd still have the gas exploding out at the same rate and at the same heat based on the properties of said gas - not of the ignition source. Considering how small a combustion chamber is in an internal combustion engine, would a dual/split fire spark plug make even the slightest difference in the resulting explosion? Or am I an idiot that cannot see the truth in the marketing?
I know that the different brands may have differing levels of durability and that is not what I am asking. I just want to know if when the spark is introduced to the air/fuel mixture, does it make a whole lot of difference?
