dusdem
Active Member
Hi, What is the best spark to use in a 318 1972 Plymouth Valiant. I have NGK in there now, I don't seem to be getting good gas mileage at all.
You might have the wrong heat range/number. I run Champions. It's what your car came with. I would run RN14YC's. Make sure your choke is pulling off fully, the engine is getting to operating temp, and that there are no vacuum leaks.Hi, What is the best spark to use in a 318 1973 Plymouth Valiant. I have NGK in there now, I don't seem to be getting good gas mileage at all.
THANKS !!!!!!You might have the wrong heat range/number. I run Champions. It's what your car came with. I would run RN14YC's. Make sure your choke is pulling off fully, the engine is getting to operating temp, and that there are no vacuum leaks.
No kidding. You must have a death wish. LOLE3 plugs. Just stirring up the pot with that suggestion.
LOL makes you wonder.Champ now calls the RN14YC a #405. Guess they wanted to save money on print ink on the boxes..
Thanks. I got them and the car is running great...LOL makes you wonder.
