[SOLD] Special Delivery Road Trip Sale
RAT ROD AL
MOPAR ARCHAEOLOGIST - one parts hoard at a time!
Homeless
Window of opp has closed !!!
Gotta make it happen fast cause I'm leaving this Monday morning. SW Florida north on 75 to Chattanooga , 24 to Kentucky on to the St. Louis area (Wentzville). Then on south 55 to New Orleans and back on 10 to 75. Can meet up along the way for a drop off to save on shipping on these bigger Items I have listed here. I would like to get a small deposit via PayPal to insure the deals,
Limited space left on truck.
#1
[FOR SALE] - Edelbrock STR15
Edlebrock STR15. Fits Low Block 383-400. New / Un-used . the logo has been ground off, for stealth reasons . 600 CFM s and linkage all included for $2500
#2
This kit is missing a couple straight pieces of tube and 2 floor plates. Has an extra drive shaft loop included. $200
#3
New Cast Steel . Stock stroke 360.. $350
#4
****SOLD ****
Set of 17x8 aluminum Ralleys 4 1/2" bolt pattern with performance radials never run on the street. Almost like new, few light scratches from moving around the shop. $1600
More parts below in next post !
Fiberglass Dart hood 67-69 with scoop. Hinge mount. $550
#6
Hotchkis A body springs . Have been mocked up never run on a project car. $350
1967-1976 Dodge A-Body Geometry Corrected Leaf Springs
#7
Narrowed 8 3/4 with Moser35 spline axles and spool. 49 3/4 " flange to flange. 43" spring pads
$800
I also have this narrowed 8 3/4 . This one uses stock 30 spline axles and spool. Dual bolt pattern @ 4 3/4" & 5"
$800
Thats all !! Thanks for looking. PM me with any ????
OOOPs , I have these also !
#9
CC375B
A body 22" 3 core used , pressure tested good ! $200. BB or early cast pump SB.
#10
I have these old school , I was told ET slots. $150 for the set all 4 the same size. Uni lug. I have only 12 washers .
Cleaned up pretty nice with a quik wire wheel . They do have minor battle scars / character !.
Any idea what time you will be in Chatanooga? It's about 10 hours from your place.
Not sure , JD. Why do you ask? Already have 3 stop/drops below Chattanooga.
