Spectra Premium radiators - any good?
Desert Fox
Member
OR
I'm looking for a new radiator for my '70 Dart Swinger 340. I found that Spectra Premium makes a radiator that looks identical the stock factory unit. Does anyone have any experience with these? Are they any good? Will the factory fan shroud mount up to it correctly?
Thanks!
i got one for my mild 318 runnin classic air a/c did not do the job i also had a new repo shroud. i had almost 450 dollars for radiator and shroud did not do the job i ended up with wizard aluminum 2 row a bit pricey but if i had not wasted the 450 would have only been 160 more dollars for the wizard setup with thier alum sdhroud you can use factory shroud on thier rads if you want or get thier combo for 615 shipped well worth it 107 heat index car runs 190 ideling 170-180 on road
