It’s been a long time since I flow tested a stock Edelbrock head and one ported but retaining the stock sized valves (2.02). There was some interest in head tubing yesterday so I’ll touch on that again. After I finished flow testing the TrickFlow head with Victor340 and Wilson spacer I removed it from the bench and grabbed two assembled Speedmaster heads. This is the first set I bought assembled and the springs, retainers, and keepers look pretty nice. What I did notice was that there were five what look like hardened valve spring shims under each spring. They measure close to .142 on the exhaust and .132 on the intake valves. Then I bolted one on the flowbench and did a flow test. Numbers posted. I with update with ported numbers from the same port after a five angle intake side valve job and porting work is finished. Then I drilled the two common wall head bolts out to 9/16 and hand drilled the four pushrod holes out to 17/32. Because of the way the pushrod holes are cut they are easier to drill from the finished (head gasket) side then flip the head over and drill from the top. One head will take four 17/32 and two 9/16. Pictures shows it takes very little epoxy to do one head at a time. Test fit all pieces before applying epoxy.
