I may be better with a 2 inch spacer then. I’ll dig out the intake and get some pics. Kim
Those chinese intakes are SMALL in X section...I removed one on a 430HP engine, put on an OOTB air gap and picked up 30HP and 20TQ. NO ****!
So maybe a better choice for a stock stroke motor with some unworked heads?
Yup. Port size was pretty close to a stock magnum head if I remember right.for 130.00 you can’t beat it for something like that.
Lol. I’m not showing you guys my tool movement. That’s asking for to much. Lol.
I’m not sure he is on here, but he my be. And just in case he ever stops by here, I want him to know what I think of him, since I haven’t told him since 2003 when I said it to his face.
If a had one sitting hear I would gladly do it but at this stage I think it would be wasted time. Who in their right mind would pay or port a set of small block heads to the 280cfm area and throw an out of the box (especially dual plane) intake on it.
Ok guys I guess I’m happy with this intake tested on Ethans Speedmaster heads. It petered out a little at mid lift and I’m pretty sure I know what it needs but because it will be going on a set of Edelbrock heads that flow 318cfm I’m not touching it till I flow it on those heads. This is going on a stock 360 (cut down to Chevy size) crank engine that will run 9’s in my car. I will probably be opening up the intake face on this intake for those heads. If you remember my 200cfm by .300 lift is beat even with the intake bolted on. It sure does make the speedmaster intake look pathetic. View attachment 1715678246
Sorry for the multiple questions , is there a lot of potential available in porting the victor 340 inlet? A friend is running a stock one on a 408 stroker running ported cast heads and im curious if you think porting it will be worth the effort.
I saw the numbers on the ported victor 340 on the ported speedmaster heads, was just wondering if you flowed the stock victor 340 stock on the same heads. I might have missed that amongst the other posts.Did you check out the numbers on my ported Victor340 in this post earlier. It responds very nicely to some needed porting work.
No this intake was here for 3-4 years and I started porting it before so I couldn’t give a stock baseline. But I have before and they do need at least gasket matched and up into the runner to blend it in. I never just do that to them though as I like to push the limits.
This might be common knowledge but I want to ask the question to confirm it. Is one of the goals when porting heads and intake, to create a port tract through the intake runner, into the head, and on to the chamber that is reducing slightly in cross section as it goes? Tight or loose spots along the way are to be avoided as much as possible of course. From what I remember of fluid dynamics in college, that would seem to be better than it opening up as it gets to the valve area. This may be an oversimplification, but it's how I think about it at the moment.No this intake was here for 3-4 years and I started porting it before so I couldn’t give a stock baseline. But I have before and they do need at least gasket matched and up into the runner to blend it in. I never just do that to them though as I like to push the limits.
What are the chances you can get your hands on one of the new TF small block intakes to see how it compares out of the box? I think that would be a lot more compelling than looking at an Air Gap.
John, we’re very glad u posted all the pics and info with all ur hard work. Thank u very much. Kim
Thanks guys. It has its place but I guess making this work on a 550 shortblock is like me trying to date a 24 year old beauty queen that owns a Helcat challenger.
I bet most people eyeballing those are sold on that, along with that it’s “aluminum and looks the part” and it’s cheap. No other reason otherwise.My opinion is it's a great intake to slap a 5.2/5.9 magnum in your classic. I've never considered it a real HP maker.
I have 3 of them, for the specific reason of they work on LA/Mag and they are cheap. I installed one on the 318 truck and it worked great on the stock 318. Fitment was great as well. I wouldn't pick the intake for a 475 HP build...I bet most people eyeballing those are sold on that, along with that it’s “aluminum and looks the part” and it’s cheap. No other reason otherwise.
