I have the same rockers but they came with roller bearings. There were clearance issues and I had to do quite a bit of work with them before they would fit.
Just before I finished going through them I learned about B3 Racing and their geometry correction kits. I would highly recommend looking into that first before doing what I did.
I used a dremel to get them to fit the retainers. I colored the area with a sharpie, installed for a test fit, and ground more wherever there were clearance issues. Most of them did not require a whole lot of material to be removed, so I am hoping that I did not weaken them significantly.
It would appear that the original machining on the ones I got had more clearance than those that CRUZE had.
I also could not find any way the roller tips ro get oil, so I drilled the smallest hole I could into the top of the rocker. Hopefully it actually gets some to the rocker and doesn't just spray it everywhere. If you look closely you can see where in that last picture.
I just got the engine back in the car after getting it back from machine shop purgatory. I have run it through the cam break in procedure, but I haven't had the valve covers off yet to see how things are holding up in there. I will update once I do.
View attachment 1716337244View attachment 1716337246View attachment 1716337248View attachment 1716337250
