What plugs are ya using with these heads?
I’ll be using the autolite 5224.
I prefer champions, but I'm running 5224s because I could get them at the parts store. I feel like the extra electrode length helps unshroud the plug.
I believe the RC12YC should be available and any parts store. At least I've not had a issue. It's basically a magnum plug (just smaller hex socket than the original RN12YC)I prefer champions, but I'm running 5224s because I could get them at the parts store. I feel like the extra electrode length helps unshroud the plug.
I wish they hadn’t edited out the exhaust stroke so we could see what was happening during overlap, but its interesting to see what’s going on there.
That's why I did what I did. I made it look "semi" like TF. And there is a plug that extends further down, TurboGLH posted it aboveSpeedmaster and Edelbrock is just as bad. View attachment 1715682694
I look at it this way, I ran 9.74 on alcohol with my Edelbrock heads like that. I run an AR3911 plug and I’m not switching so now every head Edelbrock, speedmaster type of head I touch will be relieved around the plug and radius’s. It can only help.
One of my greatest achievements in life will be having called attention to this little detail, I’ve made my mark in the Mopar world!I look at it this way, I ran 9.74 on alcohol with my Edelbrock heads like that. I run an AR3911 plug and I’m not switching so now every head Edelbrock, speedmaster type of head I touch will be relieved around the plug and radius’s. It can only help.
What timing made best power?
locked?I put it at 35-36 and never touched it.
locked?
Flat top with quench?
How much compression?flat tops in the hole with the 340 open chamber style Edelbrock heads. 1008 fel pro gasket.
Oh nice! I'm guessing Cometic head gaskets?
