Yes! you're correct dropping the column at least the three bolt to the dash frame does make it easier to remove and install. It also helps to reduce scratching it.
Here is a step by step I wrote before for someone else w/ a 67. I may have missed a step or two off of my head but this should about get it and is the quickest/easiest way I know to do one. I have done a lot of 'um! adjust for year, omit radio steps for 68-9.
disconnect battery.
remove cover from bottom of steering column, 4 screws
removes 3 bolts that retain column to bracket
remove two slide knobs from heater control (allen head)
remove radio knobs
remove two nuts holding radio to bezel
remove knob from wiper sw, remove nut. let sw stay.
remove headlight sw pull handle, push down button from behind to release, remove nut from h-light sw
remove reset knob for tripmeter unscrews counterclockwise, might have to hold shaft.
remove nut from flasher sw
from under
disconnect speedo cable
disconnect 3 prong connector from PCB on left side
disconnect connector from PCB on right side (main)
remove vac line from vac gauge if equipped, tach wires etc.
in front again
remove phillips fillister screws from bezel
pull dash forward slightly
disconnect connector from heater sw
disconnect two 3/8 bolt holding heater control from bezel frame
remove two 3/8 bolts from amp gauge
while pulling down on steering wheel to drop column a few inches remove bezel (if it doesnt want to drop enough. remove 3 bolts securing column to firewall.
with bezel out of car remove all 5/16 in bolts securing the bezel to the frame
remove bezel from frame
remove 2 flat head screws securing the speedo to the frame
remove speedo.
reverse order to reinstall.
The service doesn't say anything about lowering the steering column. Wouldn't that make it easier??
Treblig
