dodgedart1968
1968 Dodge Dart with Torqueflite
I'm trying to remove my speedometer cable to install a replacement. The first image is the installed cable. The second image is the replacement supplied by RockAuto.
I assume that I remove the installed cable by twisting the small cylinder adjacent to the large nut. It looks similar to the end on the new cable, but I would like to confirm the procedure before I start to avoid causing damage to the cable.
(The wetness seen in the image is from penetrant. The area was dry before I sprayed it.)
What is the function of the large nut?
