Greendust
Active Member
How do you lube a speedometer and what type of lube?
Agree. What I used on my old 71 years ago. Also used WD-40 to get it down into the cable housing. Used the graphite as what is used for locks. Getting to the cable housing is the biggest part of the task.Speedometer cables are not supposed to have any type of grease. The correct type lube is dry graphite powder.
Any type of grease will gum up and cause problems later on down the road, because it will overheat eventually. Speedometers cables rotate very fast and will overheat grease and break it down over time. Graphite powder will not.
I cleaned all the componenets in mine, and used weed eater cable lubricant. no worn parts to be seen, and it still bounces about 5 mph.So I put the lube where it goes into the speedo housing and I also used it on all the little gears and such.
Been about 8 years now. No issues, and I had some real problems. The needle would bounce and the gears would tick. There was grease on the gears from the factory but it was all dried out.
I drive my car what I think is a lot. I have put about 48 thousand on it over 30 years. That's also including 10 deployments which equals about 7 years of being gone. So figure 23 years total. Minimal in winter, about 2-3 thousand miles a year 600 round trip to Carlisle every year that I could go.
Yeah I'm anal on numbers.
Rick
