Speedomotive engines
George......it was a $1000 worth of parts. My issue with the lifters was that the roller pins worked there way out and a roller took the motor out. My problem with this whole thing is...they leveraged there margins at my expense. I was charged for Comp lifters...and got junk. Anyway the motor was filled with roller pieces..taking out the cam,2 pistons....barely saved the block. Also engine was built with no cam end play.....As far as you winning your court case against 440 source.....Guess they forgot to include the money I am out. Looking at the responses on this site......operating with out integrity seems to be your way of business.
Roller cams should have almost no end play .005 to .010 max, maybe they did not index the lifter bore correctly did they charge you for the lifter bore indexing?
