Speedway motors gasser kits?
devond6599
Member
hollister,ca
Has anyone bought the speedway motors gasser kit ? I want to buy one for my 64 dart but not sure witch one to go with and what width to go with? And chevy or ford type spindles? Can anyone help point me in right direction? Thanks!
im assuming you mean straight axle kit??
goes in good but you'll probably need the 4" drop like we did. Also do not go more than 5 degree's caster, it will be wild and untamable even with a dampener!
yes i guess i should have put straight axle kit rather then gasser, what width did you go with?
what ever it needed, i dont remember now... you need to figure out what your car needs, which we dont know what that is yet...
its a 64 dart gt, had front end damage when i bought the car so had no measurments to go off of, and cant seem to find track width for the car anywere.
Neither spindle type will match what you have in the back stock. Do you plan to go with a 8 3/4 rear? I would go with the ford spindle because you will get a 5 x 4.5 bolt pattern and will match a 8.75 or a Ford 9.
