Mister Twister
When we installed the spool this week noticed the passenger adjuster only adjusts passenger Axel play now. When it did both before. I go to the machine shop he said not to worry about it they dint make adjusters for the them anymore. He said do you have another set of axles? We will make both sides without adjusters and your done.
Now the right side adjusts fine but the driver moves in and out way to much for me. First time we put the brakes on, it took the spring kit off the backing plate!
Now this has probably been done before. Why not use the adjuster on the driver side also?
Choices what about those green barrings or is it a waste of money? Don
