aa-1159 Well-Known Member Joined May 4, 2006 Messages 96 Reaction score 7 Location Chester. Va. 23831 May 12, 2024 #1 Do I need to run spring dampers with this cam 360, 30 over 202 valves
4spdragtop FABO Gold Member FABO Gold Member Joined Aug 28, 2009 Messages 39,785 Reaction score 23,170 Location Ontario Parts Unknown May 12, 2024 #2 If recommended, I would.
O OldmanRick Well-Known Member Joined May 11, 2012 Messages 7,465 Reaction score 1,391 Location Ladson, Sc May 12, 2024 #3 Comp 901's should fit the bill.
RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member Joined Jun 7, 2010 Messages 105,448 Reaction score 103,487 Location Georgia May 12, 2024 #4 You need to run the valve spring that camshaft calls for.....whatever it is. Probably as mentioned, it's the Comp 901-16 which has dampers in already.
