meathead66
Mod Top
I need suggestions as where to weld in the spring perches. I know it should be in the car with the engine and trans in place in order to get the correct pinion angle however that isn't possible cause the car is on a rotisserie. Car is 69 Dart with mini tubs and a Dana 60. Anyone have some measurements with the the Dana pinion parallel to the ground from the ends of the pumpkin? Yes I know its unorthodox but I only have access to a welder for the week. Pictures would be appreciated.:cheers:
