SS braided Flex hose
barracudadave67
Burlington, Wi.
Does anyone know the type of ss braided flex hose to use for transmision lines, to go from the hard lines to the tranny cooler in front of the rad. I know that not all braided hose is compatible with tranny fluids.I'm making my flex lines from ss braided hose and want to get the correct type. I have been looking at "Jegs Pro-flo 200 Hose" , I'ts a nitrile hose, and thier cat says it is compatible with all synthetic lubricants. Just want to get the right hose so it dosn't dissolve on me later. Thanks
Dave C.
I don't know what it's made of. But there's a guy on ebay selling Steel braided hose with fitting for the tranny cooler aplication. Ask him what it's made of.
Mean time here are a couple sights I have found. And a clip from a former blog.
Here is the blog " :salut: "
(Hi Norm,
For your cooling lines, 6AN fittings and hoses would work well. I would recommend the braided hose over conventional rubber. Rubber hose clamps can sometimes be pesky as far as leaks and drips go. I've also seen racers lose a round of racing because they had a rubber tranny cooling line pop off. On the fittings that go into the case, make sure you get the 1/8"NPT (pipe thread) on one end with the 6AN male end on the other.
Running your cooling lines to the radiator and then to an additional cooler is a good idea. If you build a new tranny you may want to incorporate a gauge with the sending unit in the pan to monitor your transmission fluid temperature, and get an idea of how adequate your transmission cooling system is.
Chris
I use ATF+4 in my cars, which is Chrysler's newest transmission fluid specified for all 98 and up Chrysler products. It is highly recommended to use this fluid with a lock up torque converter application. This fluid has additional additives to resist heat, foaming and corrosion.) n end blog :salut:
http://www.aeroquiphose.biz/
http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?catalogId=10002&storeId=10001&categoryId=10603&parentCategoryId=10109&langId=-1[/URL]
http://cgi.ebay.com/ebaymotors/ws/e...&item=7934312319&rd=1&sspagename=STRK:MEWA:IT
