cudamark
Here's what I found. They're very heavy duty looking for sure. They have 6 1/2 leaves. The measurements I took are as follows: Center to center on the eye measures about 52". The arch measures 9" from floor to spring perch when the springs are upside down on the floor. Front measurement is 21 1/4" from eye to center bolt and 21 3/4 following the curve of the spring. Rear from eye to center bolt is 34 1/2" and 35 3/4 following the curve. These measurements are approximate as following the curve is very subjective as to where to start or end and hard to get a steel tape to cooperate. Generally center to center on all bushings and bolts. They will also vary a bit between other A-body springs depending on how much they've been arched.I just called asking if they had some ss springs that fit a 1969 dart. He said he had 1 pair used but in great condition. Leaf Springs and torsion bars are the only parts of my suspension that havent been replaced. Figured if they had some at a decent price I'd try to get them.
The guy on the phone said they didn't ha e much A-body, GTS or 340 engine stuff left. that's what I'm always interested in.
