Right. Posted weights range from 2850 to 3075 lbs. for the 273. Err on the light side or heavier side? Street strip car.
2800 rides too low for the '65 Dart?
Even with the 2800# springs it still sat higher than stock. I bought new front spring hangers that have 2 sets of holes in them so you can drop the car 1" and it still isn't down to stock ride height, but does sit about right for me.
That is a one nice dart. I may try the sliders.You could try slider in the rear as well. That will drop it down some more.
That is a nice ride as well. The wheel offset on the rear is awesome. What brand factory replacement springs did you use?I would have liked it to sit a little lower than that. But it isn't bad for 28" tires on the back. I didn't want to run blocks.
To be honest though, I would never run SS springs again and they aren't necessary anyhow.
This is my current car with factory replacement springs. I raised the front eye, nothing more, and it has 28"s on it as well.
Mtjat is a nice ride as well. The wheel offset on the rear is awesome. What brand factory replacement springs did you use?
RustyRatRod said:2800 LB work great on early and late cars, IMO
Crysler used to recommend goin to the lite side, if u can`t hit them right on !!!
