[FOR SALE] Stage 6 heads
oldkimmer
Kindersley, Saskatchewan,
These are on my 470. Short block is supposedly sold. So I have these for sale. Their still on the car. It will be awhile till I get them off. Not very good pics but this is all I have for now. Going to a RB stroker so the supporting cast will likely be for sale also. MP. blue roller rockers. Smith Brothers pushrods. MSD dist TM7 intake or Weiand T ram. CPPA 2 inch under chassis headers. Block and heads have to sell first b4 other goodies are for sale. The heads have been ported but I don’t have a flow sheet for them. They flow 320/260. When dynoe’d the engine made 655hp and 620tq. Had 108 volummetric effenciency Heads are $ 1400.00 usd. Plus shipping. U can buy the rockers, pushrods and possibly the MP valve covers with them. Thanks. Kim
Not sure on the port work. The guy that did the motor is very good at what he does. My 3300 pound car ran 10.40s with single 4bbl. Tunnel ram and 2 660s ran 10.1s. With nos 9.03. Kim
Do the Stage 6 heads use standard BB rockers or a special rocker ? What are the cam specs, roller, solid flat, etc. ? Also does the intake manifold require spacers for B to RB ? thanks Red B.
Mine use a regular MP or Crane Gold rocker. On the B block u can use a RB 440 intake. If u use a B 383 intake then u need the spacers. For a RB block u would need the spacers with a 440 intake. Cam is a comp solid roller. 265/275 108. 625 lift. Kim
O.K.er
Hope all is well... Hopefully mother nature has not hit you with anything yet..
I just wanted to ask you as I am really impressed with the Nitrous capabilities on your car.
Usually at these levels (10 seconds) you don't get much from N2O, in regards to a second off in the qt mile. As stated, truly impressive. Can you please tell me what Nitrous kit, set-up you are using and how much of a hit where you using ? (150 hp...Up, less, more etc..)
Again, one more time awesome times, astonishing nitrous set up and lastly sorry to hear the car is being torn apart.
MAPS
P.S. We were to have 30 Cms last night but it seems like they didn't want to "hit" us with anything too soon before X-mas,
It was a fogger plumbed into the bottom of the intake runners. 350 shot.
Hey there! Interested in these heads but know nothing about them.. Are these a bolt on replacement and go or is the valve geometry and spark plug angles all different and all from say a factory 452 head? Could i use my factory rockers and shafts and all? Also, are these as good or better than the aftermarket heads available like edelbrock or trick flows etc.? Sorry for the questions, just dont know much about these. I have stock 452 heads now and want a much better flowing head.
Please see post number 9 for more info. Plug angles are the same. The exhaust ports are raised some over factory. They use a standard no offset roller rocker. I suppose u could use factory rockers but I wouldn’t. That’s defeating the purpose of having good heads. I would say they are at least as good if not better than the Edelbrocks. Trick flow is the best ones out there now. Kim
What is the weight of each head? Shipping to 92585. Usually when it is over 15 lbs, fedex is the cheapest, unless it will fit in a flat rate box, but we both know those heads won't fit in one
